STL -> CAD
- x 1
- x 4
STL -> CAD
3D scanning offers huge opportunities in the area of metrology and reverse engineering. However, the scanning stage alone is not sufficient in most processes.
A pre-processed scan:
suitable as a reference material in the design process
averagely suitable for 3D printing (less demanding cases)
not suitable for use on CNC
Below is an example of reverse engineering.
In my opinion, the tactic of surface modeling is particularly noteworthy here.
- x 1654
- x 1489
Re: STL -> CAD
Hopefully CAD software will work with 3D scan and mesh better in the future.
It'll help with product development, QC and repair.
Re: STL -> CAD
SolidWorks and IV have add-ins from orther software companies that work well for this, one I use is DezignWorks, works great with our Romer arm probe and scanner, you work right inside your CAD building the part file from 2D using the probe to 3D using the scanner creating surfaces or solids.
years ago I tried Spaceclaim and they worked well with scan meshes, just didn't like the UI.
- x 818
- x 998
Re: STL -> CAD
Lately we have been pushed by our customer to convert some STL files that they provided to us into CAD models. We use Solidworks here.
These STL files are outputs from their CNC programming software (Espirit). Since they are NOT scans, they are extremely hard to work with because they have toolpaths in them.
I wonder if there is a better way. I have tried using the Scanning converters to turn things into nice swoopy surfaces, but nothing has worked so far except old fashioned elbow grease of measuring and re-modeling.
- x 2434
- x 2076
Re: STL -> CAD
Could you provide a model or something close to it, or image of what struggles you're facing..?DanPihlaja wrote: ↑Tue Sep 17, 2024 1:20 pm Lately we have been pushed by our customer to convert some STL files that they provided to us into CAD models. We use Solidworks here.
- x 1654
- x 1489
Re: STL -> CAD
Is the STL real STL file? 3D print and measure? LOLDanPihlaja wrote: ↑Tue Sep 17, 2024 1:20 pm Lately we have been pushed by our customer to convert some STL files that they provided to us into CAD models. We use Solidworks here.
Customer want to make old parts but don't have drawing and only got program for old machine?
- x 818
- x 998
Re: STL -> CAD
Frederick_Law wrote: ↑Tue Sep 17, 2024 3:26 pm Is the STL real STL file? 3D print and measure? LOL
That is correct. Customer only has program for old program.
- x 1654
- x 1489
Re: STL -> CAD
Do they know the tool size in the program?
I don't think STL contain tool info.
Basically STL is just triangles. Millions of triangles.
- x 1654
- x 1489
Re: STL -> CAD
Can you share the STL file?
- x 818
- x 998
Re: STL -> CAD
Unfortunately, I cannot. It is behind the NDA wall.
However, I will try to get an example part from one of our CNC programmers that I can share.
- x 2434
- x 2076
Re: STL -> CAD
taking the part, slicing it here and there and leaving only a sample of it and then exporting it as a .step wouldn't "work-around" the NDA...?DanPihlaja wrote: ↑Wed Sep 18, 2024 11:44 am Unfortunately, I cannot. It is behind the NDA wall.
- x 1654
- x 1489
Re: STL -> CAD
I'll say no, after all the pager explosion.AlexLachance wrote: ↑Wed Sep 18, 2024 11:59 am taking the part, slicing it here and there and leaving only a sample of it and then exporting it as a .step wouldn't "work-around" the NDA...?
It's not just stealing the design anymore.
Oh, today Walkie talkies.
- x 818
- x 998
Re: STL -> CAD
Unfortunately, with the amount of surfaces (over 600,000) on this thing (after I turn it into a solid), "slicing it here and there and leaving only a sample of it and then exporting it as a .step" would take me about 3 hours. Assuming Solidworks even allowed the cuts to happen in the first place....AND it will allow a STEP file translation. Most of that 3 hours is waiting for Solidworks to catch up (and yes, we have contacted Solidworks AND tested this on something top of the line....and it didn't save much time). And then on top of that, the STEP file would probably take an entire night to translate.AlexLachance wrote: ↑Wed Sep 18, 2024 11:59 am taking the part, slicing it here and there and leaving only a sample of it and then exporting it as a .step wouldn't "work-around" the NDA...?
OUr VAR told us that we are already doing everything that we can to minimize loading times.
- x 1654
- x 1489
Re: STL -> CAD
3D print it and measure and remodel.
