Has anyone ever had an error while doing a simulation that said something along the line of "Storage not found for study"? If so, anyone know what causes it and how to avoid it...?
It's quite an annoyance, the study is deleted without reason and throws off that error. Multiple users have had this issue.
- x 2348
- x 2005
Re: Storage not found for study
- x 2348
- x 2005
The file and the study are saved locally. Will check next time if the study still exists locallySPerman wrote: ↑Mon Sep 30, 2024 12:49 pm Could it be related to this?
SOLIDWORKS Simulation Results Save Location
- x 37
- x 95
Yep, I just had that happen this morning. I'm storing studies locally because Simulation and PDM don't play well together, so location isn't the problem.AlexLachance wrote: ↑Mon Sep 30, 2024 11:48 am Has anyone ever had an error while doing a simulation that said something along the line of "Storage not found for study"? If so, anyone know what causes it and how to avoid it...?
I’ve run into that error too. Have you checked if your local file paths are correct? Sometimes permissions can mess things up. Also, see if SOLIDWORKS is set to save backups.
