How to enable "Thread class" in Hole Wizard Property Manager
loeb
x 38
x 10
Unread post by loeb »
I am trying to edit the definition of an existing hole wizard hole. I can figure out how to change all the settings in the following image, except I can't figure out how to enable/disable the check box before "Thread class"
For example, I use the statement
swWizHole.CosmeticThreadType = swCosmeticThreadWithoutCallout
to disable the "With thread callout" check box
I would expect a statement like
swWizHole.ThreadClass = true
would check the "Thread class" box, but it doesn't (I just made up that property)
Any ideas how I can enable the "Thread class" check box?
RonE
x 18
x 33
Re: How to enable "Thread class" in Hole Wizard Property Manager
Unread post by RonE »
ThreadClass Property (IWizardHoleFeatureData2) requires a string value:
One of the following thread classes:
1B
2B
3B
This property is relevant only for the ANSI inch standard.
see https://help.solidworks.com/2024/englis ... class.html
retonny77
x 6
Unread post by retonny77 »
I totally understand your frustration. To enable the "Thread class" checkbox in the Hole Wizard Property Manager, you might want to try using the `swWizHole.ThreadClass` property
