Making solid STL from SW assembly
Petertha
x 11
Unread post by Petertha »
I made this assembly comprised of a left & (mirrored) pipe part files, orientated them a prescribed way & added some bridge elements. Like a plastic model sprue tree. So of course the mates between parts are like zero dimension gaps. When I did a file save as .STL of the assembly, I crossed my fingers that it might magically see it as one solid body & weld them together, but alas No. It makes a corresponding series of separate STL part files which kind of defeats the purpose of the orientated bridged assembly.
Any recommendations how to solve this issue? I don't have much of any 3DP experience. I see what looks to be complex 3DP objects like a bearing with the balls in the races. But maybe that 'works' because they are indeed separate parts? I'm not aware of a way in SW to make a Boolean solid from an assembly like the way we can choose to join new body elements within parts files. If SW could somehow make a solid body assembly this way, I'm sure converting to STL would be straightforward. Thanks for any suggestions.
zxys001
Answers: 5
x 2327
x 1005
Re: Making solid STL from SW assembly
Unread post by zxys001 »
Hello Pertertha, for a single file you could Save your SLDASM as a SLDPRT. Then saveas a STL. (it will likely have the 5 bodies but will be a single STL.
Also, try if you can "Combine" the 5 bodies into 1 and saveas a STL.
x 2282
x 1921
In the slicer I use (bambulab), if you import all of the bodies at once, it will locate them as they were in the assembly.
(Having said that, I am usually importing from a multi-body part, not an assembly. I'm not sure if that will make a difference.)
x 23
x 541
You actually want them to print as one combined piece, right? Unless you have a way to combine in the slicer/post-processor, the only way is per zxys001's suggestion - Save assembly as part, then use Combine feature or some small extrude features to combine all the bodies into a single one before saving as STL.
Petertha
x 11
Thanks! (hopefully). It never would have occurred to me to save an assembly as a part. Yet another thing I have not done in SW but probably should have been aware of. I check selected 'preserve geometry references' just as guess insurance. If all the components are defined/mated in the assembly, is this doing anything specific? Or maybe a better question: what exactly does checking this do?
SNAG-08-01-2025 7.57.23 AM.jpg (22.49 KiB) Viewed 134 times
x 2434
x 2076
Petertha wrote: Wed Jan 08, 2025 10:02 am Thanks! (hopefully). It never would have occurred to me to save an assembly as a part. Yet another thing I have not done in SW but probably should have been aware of. I check selected 'preserve geometry references' just as guess insurance. If all the components are defined/mated in the assembly, is this doing anything specific? Or maybe a better question: what exactly does checking this do?
This should be a good explanation for you mate!
https://www.goengineer.com/blog/solidwo ... references
