3 point rectangles
MattW
x 5
x 36
3 point rectangles
Unread post by MattW »
When sketching 3 point rectangles, this option exposes itself AFTER drawing the rectangle, but only applies to subsequent rectangles. Is there a way to expose the option before, or get it to apply to the rectangle just drawn? The workflow now is to draw a rectangle, click 'from midpoints', draw another rectangle, and then delete the first. It is sort of trivial, but I would like to know if there is a way
DLZ_SWX_User
x 222
x 33
Re: 3 point rectangles
Unread post by DLZ_SWX_User »
It is there as soon as I select 3 point rectangles. Unless I misunderstood your question. See video clip.
SOLIDWORKS 2020_2025.01.08-13.51_clip_1.mp4
(13.85 MiB) Downloaded 23 times
x 23
x 541
What release are you running? I’m running 2024sp2, and this is what I get as soon as I activate the 3-point rectangle:
x 2434
x 2076
MattW wrote: Wed Jan 08, 2025 1:37 pm When sketching 3 point rectangles, this option exposes itself AFTER drawing the rectangle, but only applies to subsequent rectangles. Is there a way to expose the option before, or get it to apply to the rectangle just drawn? The workflow now is to draw a rectangle, click 'from midpoints', draw another rectangle, and then delete the first. It is sort of trivial, but I would like to know if there is a way
It is there, the "3 point rectangle" feature toggles the one next to it, notice the slight difference between the images ;)
x 2282
x 1921
Try picking the Center rectangle
x 2434
x 2076
josh wrote: Wed Jan 08, 2025 2:07 pm What release are you running? I’m running 2024sp2, and this is what I get as soon as I activate the 3-point rectangle:
Okay, seeing Josh say this makes me doubt what I just said, this could be a language thing on my end lol
x 220
Unread post by Dwight »
There's an option in the dropdown menu in the CommandManager:
MattW
x 5
x 36
2024 sp5
3 point CENTER rectangles. I am not sure why @AlexLachance has trouble reading my mind. ;)
You guys are getting different behavior than me. I thought it might be related to use of the command manager, where I am using the sketch square flyout off my sketch shortcut key, but that isn't it. If I select center rectangle or 3 point center rectangle, the options do not appear until I have drawn a rectangle.
Oddly, if I select Corner Rectangle or 3 point Corner Rectangle, and then select the "Add construction lines", the options appear, although the square drawn behaves as if it were a regular Corner Rectangle or 3 point Corner Rectangle.
Thanks all for checking.
MattW
x 5
x 36
I just found out you can "Add Constuction Lines" in a Parallelogram. Kind of fun to play with. You get different behavior dragging a corner around between from corners and from midpoints.
