Assembly Sort
Library for macros
Bryan O
x 18
x 37
Assembly Sort
Unread post by Bryan O »
Anyone have a macro that will sort the components of a feature manager tree of an assembly alphanumeric?
by Stefan Sterk » Thu Jan 09, 2025 3:09 pm
Funny you ask, there was some activity on my solution at the SOLIDWORKS forum yesterday.
The code below should do the trick. UU
Option Explicit
Declare PtrSafe Function StrCmpLogicalW Lib "shlwapi" (ByVal s1 As String, ByVal s2 As String) As Integer
    Dim swDoc As SldWorks.ModelDoc2
    Set swDoc = swApp.ActiveDoc
    If swDoc Is Nothing Then End
    If swDoc.GetType <> swDocASSEMBLY Then End
    swDoc.FeatureManager.EnableFeatureTree = False
    ' Sort assembly components
    SortAssemblyComponents swDoc
    swDoc.FeatureManager.EnableFeatureTree = True
Function SortAssemblyComponents(swDoc As SldWorks.ModelDoc2)
    Dim swAsm As SldWorks.AssemblyDoc
    Dim swComp As SldWorks.Component2
    Dim swFeatmgr As SldWorks.FeatureManager
    Dim swConf As SldWorks.Configuration
    Dim swRootComp As SldWorks.Component2
    Dim swFeatFolder As SldWorks.Feature
    Dim vChildComp As Variant
    Dim i As Integer, j As Integer
    Set swFeatmgr = swDoc.FeatureManager
    Set swAsm = swDoc
    Set swConf = swDoc.GetActiveConfiguration
    Set swRootComp = swConf.GetRootComponent3(True)
    vChildComp = swRootComp.GetChildren
    For i = 0 To UBound(vChildComp)
        For j = i + 1 To UBound(vChildComp)
                If StrCmpLogicalW(StrConv(vChildComp(i).Name2, vbUnicode), StrConv(vChildComp(j).Name2, vbUnicode)) = 1 Then
                Set swComp = vChildComp(j)
                Set vChildComp(j) = vChildComp(i)
                Set vChildComp(i) = swComp
        Next j
    Next i
    vChildComp(0).Select4 False, Nothing, False
    Set swFeatFolder = swFeatmgr.InsertFeatureTreeFolder2(swFeatureTreeFolderType_e.swFeatureTreeFolder_Containing)
        swAsm.ReorderComponents vChildComp(i), swFeatFolder, swReorderComponentsWhere_e.swReorderComponents_LastInFolder
    Next
    swFeatFolder.Select2 False, -1
    swDoc.Extension.DeleteSelection2 swDeleteSelectionOptions_e.swDelete_Absorbed
End Function
Stefan Sterk
x 53
x 81
Re: Assembly Sort
Unread post by Stefan Sterk »
Option Explicit
    Set swAsm = swDoc
        Next j
    Next i
    Next
End Function
Bryan O
x 18
x 37
Re: Assembly Sort
NICE! Works exactly how I hoped!
It sorts everything in the feature manager, subs included (but not the components of the subs, as expected).
Thank you!
loeb
x 40
x 10
Re: Assembly Sort
Unread post by loeb »
Can you help me understand the first line:
-Thank You
Stefan Sterk
x 53
x 81
Re: Assembly Sort
loeb wrote: Thu Jan 09, 2025 11:16 pm Can you help me understand the first line:
-Thank You
Hi Loeb,
Just declaring a function from the shlwapi.dll. Having this line makes the code more copy past friendly.
Otherwise you would need to reference the shlwapi.dll library. Which isn't referenced by default. Does this make sense for you?
Description for the StrCmpLogicalW function.
Compares two Unicode strings. Digits in the strings are considered as numerical content rather than text. This test is not case-sensitive.
So the following names part1, part2 and part10 will be sorted like;
part1
part2
part10
Instead of (with the default VBA StrComp function)
part1
part10
part2
x 23
x 541
Re: Assembly Sort
Shoot... Wish I had known about this a while back. I basically rolled my own version, which was a bit of a pain in the butt. Thanks for the info!
loeb
x 40
x 10
Re: Assembly Sort
Stefan Sterk wrote: Fri Jan 10, 2025 2:28 am Just declaring a function from the shlwapi.dll. Having this line makes the code more copy past friendly.
I get it. Thank you for the explanation. I have to wonder what other libraries I don't know about.
