Set Default BOM Part Number to Document Name
Posted: Tue Feb 18, 2025 4:13 pm
by sjbennett88
I have a script that automatically suppresses threaded features and decreases image quality of parts, specifically designed for McMaster components. I am trying to add in functionality that would set the default BOM PN display to show the Document Name rather than Configuration Name. I thought had the language right, but the line I added doesn't seem to do anything (as can be seen by checking the value of swUserPreferenceIntegerValue_e.swDefaultBOMPartNumberForNewConfig before and after that line). What am I doing wrong?
Note - I am not very experienced with the SolidWorks API or programming in general - please be kind
Here is the relevant code. The lines in question are all the way at the bottom:
Option Explicit
Const APPEND_SELECTION As Boolean = False
Const TYPE_NAME As String = "3DProfileFeature" '3DSketch
Sub main()
    Set swModel = swApp.ActiveDoc
    Dim Part As Object
    Set Part = swApp.ActiveDoc
    Dim bRet As Boolean
    Dim i As Integer
    Dim CurVal As Double
    Dim MaxVal As Double
    Dim MinVal As Double
    Dim NewVal As Double
    Dim IntegerSetting As Integer
    If Not swModel Is Nothing Then
        Dim vFeats As Variant
        vFeats = GetAllFeaturesByType(swModel, TYPE_NAME)
        swModel.Extension.MultiSelect2 vFeats, False, Nothing
        'If swModel.Extension.MultiSelect2(vFeats, False, Nothing) = UBound(vFeats) + 1 Then
            'Err.Raise vbError, "", "Failed to select features"
        'End If
        For i = 1 To swSelMgr.GetSelectedObjectCount
            Set swFeat = swSelMgr.GetSelectedObject5(i)
            If Not swFeat Is Nothing Then
                bRet = swModel.EditSuppress2: 'Debug.Assert bRet
            End If
        Next i
    Else
        MsgBox "Please open model"
    End If
    'Reduce image quality
    swModel.Extension.GetUserPreferenceDoubleValueRange swImageQualityShadedDeviation, CurVal, MinVal, MaxVal
    NewVal = ((MaxVal - MinVal) * 0.2) + MinVal
    swModel.SetUserPreferenceDoubleValue swImageQualityShadedDeviation, NewVal
    'Reduce wireframe quality
    swModel.SetUserPreferenceIntegerValue swImageQualityWireframeValue, 15
    'Debug.Print swModel.swBOMPartNumberSource_e.swBOMPartNumber_ConfigurationName
    'Set default BOM PN to Document Name - doesn't work yet
    swModel.SetUserPreferenceIntegerValue swUserPreferenceIntegerValue_e.swDefaultBOMPartNumberForNewConfig, swBOMPartNumberSource_e.swBOMPartNumber_DocumentName 'swBOMPartNumberSource_e.swBOMPartNumber_DocumentName
    IntegerSetting = swModel.GetUserPreferenceIntegerValue(swUserPreferenceIntegerValue_e.swDefaultBOMPartNumberForNewConfig)
    'Debug.Print IntegerSetting
Re: Set Default BOM Part Number to Document Name
Posted: Wed Feb 19, 2025 10:00 am
by Stefan Sterk
Hi Sjbennett88, Have you seen the macro in the link below?
https://www.codestack.net/solidworks-ap ... m-options/
Posted: Fri Feb 28, 2025 2:58 pm
by sjbennett88
That was exactly what I needed. Thank you!
