I found a video of me trying to keep up with all the ways custom properties and data card variables and $PRP... on drawings can go wrong.
I found a video of me trying to.... ...custom properties... beep beep beep.
Re: I found a video of me trying to.... ...custom properties... beep beep beep.
Soooooo, you are feeling frustrated?
- - -Randy Pausch
- - -Randy Pausch
Frustration comes and goes. Mostly weary of the 1k little cuts.
Today is putting the Thickness, Material and Weight custom properties back into a sheet metal files so they show up on print. I don't know if they're just older and the templates were from early on (we've changed them a few times during lift off) or user was fixing, or... Then there's another config so I have to add them to the other config too, unless there's a way to update all configs at the same time, when adding custom properties.
- x 1157
- x 1957
@bnemec You should try out Windchill.
- x 2290
- x 1964
I use a program for my custom properties, but I've seen plenty of users who do use them get away with it just fine. If I'm not mistaken @Roasted By John uses them extensively
- Roasted By John
- x 268
- x 583
Yeah I got a few macros that I used to use (pre - Fusion 360)AlexLachance wrote: ↑Thu Apr 29, 2021 1:41 pm I use a program for my custom properties, but I've seen plenty of users who do use them get away with it just fine. If I'm not mistaken @Roasted By John uses them extensively
@bnemec - not sure if the attached are what you want or not, let me know there's more
- Configuration-Custom.swp
- (31 KiB) Downloaded 56 times
- SW_Import_Export Properties-TEMPLATE-Test.zip
- (5.97 MiB) Downloaded 62 times
www.martinsroastapig.com
Pig Roast Your Way
Pig Roast Your Way
- x 1613
- x 1454
Put custom property in the config side without a config and watch someone else try to change the property in drawing.
