Select Components
Library for macros
Rob
x 787
x 208
Select Components
Unread post by Rob »
Maybe I skipped class on this one, but I couldn't find an easy way to select components (No component filter).
Problem: When selecting components from the Graphics Area, the selections are the actual entities of the components.
Illustrated here when saved as a Selection Set.
The attached macro will upgrade your selections to the component level - and optionally allow you to save the selection.
So with the same selections as before
note that the first selection had two entities from the same component - so the total was reduced to 3.
Hope you find it useful - or can tell me a better way
SelectComponents.zip
(10.43 KiB) Downloaded 120 times
x 815
x 993
Re: Select Components
So question:
Why do you specifically need to select the component?
The reason that I ask, is that normal assembly functions (like copy with mates, copy/paste, change transparency, hide, suppress, etc...) are applied at the component level even though you have selected a face of that part.
Rob
x 787
x 208
dpihlaja wrote: Fri May 07, 2021 8:41 am So question:
Mostly for good organisation / ease of identification - I've since added the functionality to add to a folder - which is better than selection sets because the components are reordered in the tree and I can hide or suppress en-masse.
If you select faces then the component is highlighted in the tree, but edges or vertices do not have the same behaviour.
Since I discovered that folders are as good if not better than selection sets I could perform the same job by the UI, but this is still nicer / faster.
I'm dealing with a lot of tiny fixings that are added to the assembly in an ad-hoc manner - they're a reet pain to deal with.
Ultimately this macro is part of a wider suite I am writing that attempts to automate the tedium. Having a selection set or folder is a nice way for me to provide a group of components as input to another macro.
For example, the next step in this process is to rotate each of these as the pattern in the top left - but differing by a small random amount - I did that manually a couple of times and it was enough
Tom G
x 989
x 466
Unread post by Tom G »
I usually select them in the FM assembly tree.
Appearances is one example where I would want something like paint applied to the whole component, not to selected faces and entities.
**If it helps, I'd trash that ad-hoc manner by selecting sets (rows, orientations, w/e) and establishing some folders. Conditions apply whether this task would be worth the effort.* *
Edit: oops, that IS what you are doing.
Tom G
x 989
x 466
Rob wrote: Fri May 07, 2021 9:36 am Ultimately this macro is part of a wider suite I am writing that attempts to automate the tedium. Having a selection set or folder is a nice way for me to provide a group of components as input to another macro.
I do really wish that I could select only a folder and thereby select all its contents (not only highlight it in view), but accept that folders make selecting related items easier already.
Rob
x 787
x 208
Tom G wrote: Fri May 07, 2021 9:46 am I do really wish that I could select only a folder and thereby select all its contents (not only highlight it in view), but accept that folders make selecting related items easier already.
..and that's a great idea for another macro :D
