Accurate Gears in SW
Posted: Wed May 19, 2021 8:39 am
by mattpeneguy
So, there was a post at the old forum, but since it's lost in the platform I figured I'd recreate it.
I have attached my version that I created 7 years ago. So, it can be opened by just about anyone...Though, I think it breaks if you change the parameters too drastically, even though the equation should be correct. It's been a little while (7 years) since I've messed with this model.
Hey @DennisD and @Conklin,
I believe you had even better models. Want to add them here?
Re: Accurate Gears in SW
Posted: Wed May 19, 2021 10:16 am
by sergio.monti
Thanks for sharing. Very appreciated!
Posted: Wed May 19, 2021 1:30 pm
by DennisD
@mattpeneguy, I had used the involute equation curve, but abandoned it because I wanted more control over the geometry. In particular, I use gears with a profile shift and found it much easier to accomplish with my involute curve.
Attached are files I developed using the geometric definition of an involute curve where the arc lengths, A, equal their unwrapped lengths, B. This capability (setting arc lengths equal to straight line lengths) became available in either SWX2015 or SWX2016 and really simplified the models. I just updated these files so they are saved in SWX2021.
These gears use a Design Table where you input the number of teeth, pressure angle, and module (metric) or diametral pitch (inch). They are very good for the involute profile.
Caveat emptor (Disclaimer):
These models DO NOT deal with undercuts that would occur when there are few teeth, and specifics of the root and tip radius are up to the user. They are offered simply as a good starting point for someone, but the ultimate responsibility is yours in using these models. As with threads on a fastener, often times it is unnecessary to model something with such detail, since the specification governs and not the geometry. However, since these models are easy to use for any straight gear I need there is no downside, plus they are great for 3D printing or even FEA if undercuts and radii are properly done.
If someone would like to make helical versions of these and share them here that would be great. I have not done so simply because I have not yet had the need.
I invite you forum members to also contribute more advanced parametric gear files, in particular bevel gears, spiral bevel gears, worm sets, and profile shifted gears. Profile shifting is an art unto itself and, like bevel gears, requires consideration of the mating gear.
BONUS Design Table Feature:
Normally a DT only includes the configured parameters that control the configuration. I discovered that DRIVEN dimensions
can be displayed in a DT. All you have to do is paste the parameter into the next available active column. SWX will automatically populate the values when the configurations are rebuilt. This is sometimes handy when you are developing a part and want to see the result on a parameter. In these files I used a driven dimension to measure the resulting pressure angle. Note that the values in the DT only update if the configuration has been rebuilt. These driven values are shaded blue, with inputs in green and calculated driving values in yellow. Note that some of the inputs are not direct SWX parameters, but are instead used in the calculating driving values SWX is using in the model.
Gotta love the ease of use of Excel!!
The DT's in these files also demonstrate how a blank row and column cause SWX to ignore anything below the blank row and to the right of the blank column. This is handy for notes, drop-downs, scratchpad calculations, etc.
Posted: Wed May 19, 2021 2:27 pm
by mattpeneguy
Why oh why did you upgrade them to 2021?...We're on Windows 7 here and can't install SW 2021...
Thanks for sharing them, though. I'm sure others will get some good use out of them.
Posted: Wed May 19, 2021 2:45 pm
by DennisD
mattpeneguy wrote: ↑Wed May 19, 2021 2:27 pm
Well, the files I posted are the best polished versions I have and include inch and internal versions.
I just did some digging and found one of the early version files in SWX2016, but it is only for a metric spur gear. Also attached is the collection of inch/metric, internal/external gears last saved in SWX2019.
Enjoy!
Posted: Wed May 19, 2021 3:07 pm
by mattpeneguy
Thanks Dennis!
Posted: Thu May 20, 2021 2:23 am
by Frank_Oostendorp
DennisD wrote: ↑Wed May 19, 2021 2:45 pm
Enjoy!
Thanks for sharing. Files that supposed to be saved in SW2019 show future version when opened in 2019. Could you check, Dennis?
Posted: Thu May 20, 2021 10:12 am
by DennisD
Frank_Oostendorp wrote: ↑Thu May 20, 2021 2:23 am
Sorry about that. I verified that these were last saved in SWX2019.
Posted: Thu May 20, 2021 10:55 am
by Frank_Oostendorp
DennisD wrote: ↑Thu May 20, 2021 10:12 am
Yes, these are. Thanks again for sharing.
Posted: Thu May 20, 2021 11:04 am
by TRKemp
Thanks for sharing!
Posted: Thu May 20, 2021 4:57 pm
by Hansjoerg
I found
this tool at Grabcad.com.
Does anyone know this tool or does anyone even use it?
Posted: Fri May 21, 2021 1:49 pm
by Conklin
I have posted a wile back this file
"Robust Involute Spur Gear Generator - Better 02.SLDPRT"
A "GRABCAD" link to it it here:
https://grabcad.com/library/robust-invo ... lidworks-1
it has been downloaded a "few" times and has gotten good reviews...
I think they were saved there as Solidworks 2015
Posted: Sat Jun 12, 2021 12:27 pm
by mattpeneguy
We have an old chain driven machine that I'm trying to reverse engineer some parts to possibly replace. One of them is a 15 tooth pinion. Sooo, that means undercut is present. I don't think the original gear set was profile shifted, but we need to get some better pictures of the rack gear, which appears to be the original. The machine was crammed in a corner and we didn't have a lot of access. It's only 3 miles from the office, so it wasn't a comprehensive teardown. We just wanted to get an idea of what we're dealing with.
So that brings up undercutting of the pinion to eliminate the possibility of interference, which I don't think either
@DennisD nor
@Conklin account for in their models. That's partly because nobody should be designing such gears. If you need fewer gear teeth then profile shifted gears are a better solution than undercutting...And ultimately that's probably what we'll suggest for the gear set. But for the time being I need an undercut pinion gear.
Long story short I found this site where you can create them and convert the set over to CAD:
http://hessmer.org/gears/InvoluteSpurGe ... owOption=3
When I get some time I may figure out the math behind the undercut process and maybe we could add it to one of these gear models?
Posted: Mon Jun 14, 2021 8:59 am
by DennisD
mattpeneguy wrote: ↑Sat Jun 12, 2021 12:27 pm
So that brings up undercutting of the pinion to eliminate the possibility of interference, which I don't think either @DennisD nor @Conklin account for in their models. That's partly because nobody should be designing such gears. If you need fewer gear teeth then profile shifted gears are a better solution than undercutting...And ultimately that's probably what we'll suggest for the gear set. But for the time being I need an undercut pinion gear.
@mattpeneguy What are the particulars of the gear besides number of teeth (pressure angle and module or diametral pitch)? 15T is not necessarily undercut, but if it is then yes, that is a different geometry than the files I created. I am interested in learning more about this so I could add that feature. Keep us posted with all that you learn.
