Flex feature problem
camcombloux
x 4
Unread post by camcombloux »
Hi all,
I wanted to know if it was possible to bend 4 wings of a cylindrical part towards its axis without changing its dimensions ?
The closest i came to what i need is with using the flex feature and tapering, but the width grows at the end of the wing as the length is still the same...
I hope someone will understand and help me with my problem !
Thanks in advance
Cam
by matt » Tue Jul 06, 2021 10:29 pm
The Flex feature gives you results that are mostly valuable as visual info, not precise geometrical data. I would probably cut the part in 1/4, flex it, then pattern the body. I can make an example for you tomorrow when I'm in front of a computer.
x 1225
x 2390
Re: Flex feature problem
camcombloux
x 4
matt wrote: Tue Jul 06, 2021 10:29 pm The Flex feature gives you results that are mostly valuable as visual info, not precise geometrical data. I would probably cut the part in 1/4, flex it, then pattern the body. I can make an example for you tomorrow when I'm in front of a computer.
​​​​​​​​Thank you for your advice, it worked perfectly ! UU
I used intersect to keep only one of the tangs, then flex, then circular pattern.
Ömür Tokman
x 995
x 347
Unread post by Ömür Tokman »
camcombloux wrote: Wed Jul 07, 2021 3:43 am ​​​​​​​​Thank you for your advice, it worked perfectly ! UU
Hi,
If the help solved the problem, it would be more helpful if you confirm the correct answer. Thank you for your understanding.
camcombloux
x 4
Ömür Tokman wrote: Wed Jul 07, 2021 7:32 am Hi,
Oh right !
I'm still new so i didn't know about this, just did it !
x 1225
x 2390
Great! Glad to hear you worked it out.
