G code programming & SWX
Posted: Fri Jul 16, 2021 8:53 am
by Maha Nadarasa
I have seen some job ads for Designing Engineers which ask for knowledge in CNC G code programming as well. How is it important to Designing Engineers?
Re: G code programming & SWX
Posted: Fri Jul 16, 2021 9:12 am
Its another way of saying you'll be doing more then what you're paid for.
Knowing G code and how a CNC work will help design better parts that can be made.
Posted: Fri Jul 16, 2021 9:47 am
by John
Theres a big gap between knowing about manufacturing and how parts are machined to knowing the actual G-Code. A design engineer should always understand DFM but wouldn't need to know G-Code unless they are also going to be doing CAM Programming.
Posted: Fri Jul 16, 2021 10:03 am
by Jim Steinmeyer
Frederick_Law wrote: ↑Fri Jul 16, 2021 9:12 am
If it is in the job description from the start it is not doing more than you are paid for.
Many smaller companies do not have enough budget for a separate nestor / programmer. They need someone with the ability to do it along with their regular work. The two most convenient people would be either the designer or the machine operator.
