Sketch Point Import Macro Mod
Posted: Wed Aug 11, 2021 9:24 am
Probably one for Artem but just in case anyone else knows how:
I want to create a sketch with a bunch of known points (that I already have in CSV format) so this macro is pretty much perfect.
However rather than using the global coordinate system, I was hoping to use a coordinate system I have inserted to define the origin for where the points are placed. Can this macro be modified to prompt me to select a different coordinate system?
Also less critically, my data is natively in mm where the macro requires metres. Obviously it is trivial to update the source data but it would be one less step if maybe the macro could read the document units and import as that, would that be possible?
