If a custom property has associative dimension, how would I get the value and not the dimension name
ResidentAtLarge
x 30
Unread post by ResidentAtLarge »
I am looking to link basic length and width as a custom property. So, the dimension that determines those two values are linked in the custom property which would look something like this: "Length@Sketch1@Part1" and "Width@Sketch1@Part1".
So, when writing my code it doesn't copy the Evaluated value of the custom property, it copies the "Value/Text Expression".
Is there a way to grab the Evaluated value instead of the text expression in the custom property?
The current code I'm using is :
swCustProp.Get4("Width", False, val, valout)
I am using this macro to copy data into an excel database that I've created and based on a few custom properties that are concatenated, it returns data back into solidworks. A lot of the solidworks designers here like to link dimensions to their properties to use in their BOM and I'd like to keep it that way.
by Eddy Alleman » Thu Aug 19, 2021 9:01 am
Hi,
the valout schould give you the value
val gives what is filled in and that can be an equation in your case.
from the docs:
Parameters
FieldName
Name of the custom property
UseCached
True if the configuration has been activated, false if not (see Remarks)
ValOut
Value of the custom property
ResolvedValOut
The terminology is a little confusing...
Eddy
Eddy Alleman
x 80
x 89
Re: If a custom property has associative dimension, how would I get the value and not the dimension name
Unread post by Eddy Alleman »
Hi,
from the docs:
Parameters
FieldName
UseCached
ValOut
ResolvedValOut
Eddy
ResidentAtLarge
x 30
I've always been using val in my macro. I just did not realize that valout was giving the evaluated value which I should probably be using from now on.
Thank you for clarifying that for me!
Eddy Alleman
x 80
x 89
you're welcome
We all made that mistake once, but when stepping up we use other "values" than numbers.
Happy coding
