Define Assembly Axis coincident with Center Of Mass
Rob
x 787
x 208
Unread post by Rob »
I'm looking to create a pivot point at exactly the Assembly COM.
So far I have achieved this by creating a COM feature in the assembly and then creating an assembly sketch with a single sketch point that I drag coincident to the COM point then using this point and a Plane to define the Axis.
This works but the sketch point does not update when the COM moves.
To get an update I have to delete the sketch point coincident relation and reapply it, which is insanely tedious.
Is there a nicer way to do this? Seems like there should be.
x 2489
x 1899
Re: Define Assembly Axis coincident with Center Of Mass
Rob wrote: Thu Oct 28, 2021 8:07 am I'm looking to create a pivot point at exactly the Assembly COM.
I just put a center of mass in an assembly yesterday. I hardly ever use it, but what you are asking should work.
Just tried selecting the COM and a sketch point and yep, I can't make a relation. I get it this may be intentional, as I can see some horrible circular reference scenarios, but when's that ever stopped SW? SW's motto should be "always giving the users enough rope to hang themselves".
Hey @gupta9665, it appears the COM is accessible in the API, but I'm guessing it won't update and any macro you made assigning the axis to the COM via macro would require re-running the macro? Maybe this could be handled by a Macro feature that would update with each rebuild?
http://help.solidworks.com/2012/English ... ple_vb.htm
x 1777
x 2142
mattpeneguy wrote: Thu Oct 28, 2021 8:29 am I just put a center of mass in an assembly yesterday. I hardly ever use it, but what you are asking should work.
I tried it. It wouldn't let me apply a relation by Ctrl+ selecting the sketch point (or end point of a line) and the CoM, but it would let me drag it to the CoM and apply a relation that way. I moved a component, which of course caused the CoM to move. The sketch point did not move with it, even after a Ctrl+Q rebuild. I opened the sketch, and it showed the Coincident relation, but it still didn't update.
Rob
x 787
x 208
Thanks Matt :D
I was hunting the correct API calls unsuccessfully but you showed me the way..
I ended up creating two planes to define the axis and then update the plane offsets based on the current COM.
It's a hack for sure but its working..
Option Explicit
Sub main()
    Set swModel = swApp.ActiveDoc
    Dim swMassProperty As SldWorks.MassProperty
    Set swMassProperty = swModel.Extension.CreateMassProperty
    Dim vComPts As Variant
    vComPts = swMassProperty.CenterOfMass
    Debug.Print vComPts(0), vComPts(1), vComPts(2)
    Dim swDimension As SldWorks.Dimension
    Set swDimension = swModel.Parameter("D1@COMPlaneXZ")
    swDimension.SystemValue = Abs(vComPts(1))
    Set swDimension = swModel.Parameter("D1@COMPlaneYZ")
    swDimension.SystemValue = Abs(vComPts(0))
    swModel.EditRebuild3
[edit] I added the macro to the design binder so it's pretty convenient now
GrahamK
x 3
Unread post by GrahamK »
I could be clever and say Catia as this will do exactly what you want :)
What you can try is:
Create COM
Then create 3 global variables which you can assign the values in XYZ of COM (make sure you set to automatically rebuild)
Create 3 planes paralel to Front, top, Right and link to the 3 global variables.
Create point of intersection of these 3 planes.
If the COM changes this will update the global variables which in turn updates the planes and then the point.
x 2256
x 1902
Rob wrote: Thu Oct 28, 2021 9:28 am
That should be SW motto.
Rob
x 787
x 208
GrahamK wrote: Thu Oct 28, 2021 10:02 am I could be clever and say Catia as this will do exactly what you want :)
Create COM
Perfect Graham!!
This is basically what my macro did but via equations!
SW warns about a potential circular ref, but that's fair enough
colt
x 14
x 22
Unread post by colt »
Another way is to create massless part that you can mate to the cg. Then you can mate to that object. It seems to follow the cg accurately on rebuild.
Assem1.SLDASM
(211.47 KiB) Downloaded 168 times
Answers: 25
x 815
x 993
Create COM
That is a great idea.
The only issue that I see is when/if one of the distances goes into the negative or becomes 0. How do you determine positive/negative direction?
Rob
x 787
x 208
dpihlaja wrote: Thu Oct 28, 2021 10:55 am That is a great idea.
I had the same concern, so I mated so that the assembly origin was at an extreme corner
Rob
x 787
x 208
colt wrote: Thu Oct 28, 2021 10:54 am Another way is to create massless part that you can mate to the cg. Then you can mate to that object. It seems to follow the cg accurately on rebuild.
Up there for thinking, down there for dancing!
Alin
x 265
x 391
Unread post by Alin »
In SW2022, you just need to define the Coordinate System. Its origin, planes and axes are now selectable and usable for many downstream operations (including sketching, mates and more).
x 2489
x 1899
Alin wrote: Thu Oct 28, 2021 4:45 pm In SW2022, you just need to define the Coordinate System. Its origin, planes and axes are now selectable and usable for many downstream operations (including sketching, mates and more).
Hmm. That works and should be a robust solution!
BTW, who championed adding those planes and axes to the coordinate systems? I'd like to thank them. I'd be testing this out in the Beta if we weren't stuck on Windows 7 (can't upgrade past 2020).
Alin
x 265
x 391
mattpeneguy wrote: Thu Oct 28, 2021 5:24 pm Hmm. That works and should be a robust solution!
Yes, the new functionality is pretty crazy. We can even achieve freedom from the ORIGIN!!!
I stress-test the enhancements and reported the results here:
https://www.engineersrule.com/coordinat ... -and-axes/
Alin
x 265
x 391
mattpeneguy wrote: Thu Oct 28, 2021 5:24 pm BTW, who championed adding those planes and axes to the coordinate systems? I'd like to thank them.
I asked the same question here:
https://r1132100503382-eu1-3dswym.3dexp ... NJjqu20FVg
Answers: 25
x 815
x 993
Its been in the top ten every single time I have ever participated in it.
KevinC
x 17
x 70
Unread post by KevinC »
Along the lines of colt's post, if you use a surface instead of a solid body, then you needn't worry about any effects the CG ball has on the CG calcs as it is massless and its material selection is..immaterial.
EDIT:
And apply the black/while tile texture to the surface ball to give it a CG look:
