Macro to Mate Origin - Origin
Programming and macros
zwei
x 185
x 600
Unread post by zwei »
Asking around before i start writing my own macro...
Do anyone has a macro or similar macro that do the following?
The current idea for the workflow is that:
1. Select TWO component in feature tree
2. Run the macro
3. The macro mate the two component together using origin
by Stefan Sterk » Fri Jul 08, 2022 6:22 am
I contacted API Support and they suggest using AddMate5 with swMateCOORDINATE, which will align the axes.
The code snippet below works as expected. Have fun with it ;)
Sub main()
    Dim swAsm As SldWorks.AssemblyDoc
    Dim swSketch As SldWorks.Sketch
    Dim swSkPoint As SldWorks.SketchPoint
    Dim SelComps(1) As Object
    Dim i As Integer
    Set swModel = swApp.ActiveDoc
    If swModel Is Nothing Then MsgBox "Please open a Assembly!": End
    If swModel.GetType <> swDocASSEMBLY Then MsgBox "Please open a Assembly!": End
    Set swAsm = swModel
    Set SelComps(0) = swSelMgr.GetSelectedObjectsComponent(1)
    Set SelComps(1) = swSelMgr.GetSelectedObjectsComponent(2)
    If swSelMgr.GetSelectedObjectCount2(-1) > 2 Then MsgBox "Please select only two components!": End
    If swSelMgr.GetSelectedObjectCount2(-1) <> 2 Then MsgBox "Please select two components!": End
    If SelComps(0) Is Nothing Or SelComps(1) Is Nothing Then MsgBox "Please select two components!": End
    swModel.ClearSelection2 True
    For i = 0 To 1
        Set swFeat = SelComps(i).FirstFeature
        Do While Not swFeat Is Nothing
            If "OriginProfileFeature" = swFeat.GetTypeName Then
                Set swSketch = swFeat.GetSpecificFeature2
                Set swSkPoint = swSketch.GetSketchPoints2()(0)
                swSkPoint.Select4 True, Nothing
                Exit Do
            End If
        Loop
    Next i
    swAsm.AddMate5 20, -1, False, 0, 0, 0, 0, 0, 0, 0, 0, False, False, 0, Empty
    swModel.EditRebuild3
Stefan Sterk
Answers: 5
x 73
x 88
Re: Macro to Mate Origin - Origin
Unread post by Stefan Sterk »
Hi Zhen,
The code that follows fulfills your request. The only issue I can identify is that the Origin Axes don't align as they would if I did it manually. grumph
Sub main()
    Dim swSelComp As SldWorks.Component2
    Dim swSelComp1 As SldWorks.Component2
    Dim swSelComp2 As SldWorks.Component2
    Dim swCoincMateData As SldWorks.CoincidentMateFeatureData
    Dim EntitiesToMate(1) As Object
    Dim EntitiesToMateVar As Variant
    Dim i As Integer
    Set swAsm = swModel
    Set swSelComp1 = swSelMgr.GetSelectedObjectsComponent(1)
    Set swSelComp2 = swSelMgr.GetSelectedObjectsComponent(2)
    ' Check selection
    If swSelComp1 Is Nothing Or swSelComp2 Is Nothing Then MsgBox "Please select two components!": End
    ' Get origins to mate
    For i = 0 To 1
        Set swSelComp = swSelMgr.GetSelectedObjectsComponent(i + 1)
        Set swFeat = swSelComp.FirstFeature
                Set EntitiesToMate(i) = swSkPoint
                Exit Do
            End If
        Loop
    Next i
    EntitiesToMateVar = EntitiesToMate
    ' Create CoincidentMateFeatureData
    Set swCoincMateData = swModel.CreateMateData(0)
    swCoincMateData.EntitiesToMate = (EntitiesToMateVar)
    swCoincMateData.MateAlignment = 0
    swModel.CreateMate swCoincMateData
Stefan Sterk
Answers: 5
x 73
x 88
Sub main()
    Dim i As Integer
    Set swAsm = swModel
    For i = 0 To 1
                Exit Do
            End If
        Loop
    Next i
x 2542
x 2139
Hey guys, just stopping by to hola at both of you!
zwei
x 185
x 600
Stefan Sterk wrote: Fri Jul 08, 2022 6:22 am I contacted API Support and they suggest using AddMate5 with swMateCOORDINATE, which will align the axes.
Sub main()
    Dim i As Integer
    Set swAsm = swModel
    For i = 0 To 1
                Exit Do
            End If
        Loop
    Next i
Sorry for the late reply... This totally slipped my mind after my vacation...
The macro work like a charm
Thanks a lot.
mp3-250
Answers: 20
x 767
x 384
Unread post by mp3-250 »
I was trying addmate5 for a while and the answer helped me to understand the problem was the axis alignment required an undocumented "-1" after the swMateCOORDINATE "20". lol
Thank you!
https://help.solidworks.com/2024/Englis ... Redirect=1
Member Description
swAlignAGAINST Obsolete. Do not use.
swAlignNONE Obsolete. Do not use.
swAlignSAME Obsolete. Do not use.
swMateAlignALIGNED 0
swMateAlignANTI_ALIGNED 1
swMateAlignCLOSEST 2
