I posted this question on the 3dExperience forum but it seems like posts go dead too soon.
I primarily have used solids for beam simulation but decided to try treating as a beam.
Problem: Four 50' beams supporting a load of 220lb/ft. Right and left side are separated by 18". Each side consists of a pair of beams which are to be bolted together using welded on end plates with bolt holes. See default configuration.
Setup: Since I'm only concerned about beam selection at the moment, I will consider the two halves on a side as one 100' beam which by symmetry takes 110lbs/ft = 9.166 lbs/in load. With a F.O.S of 1.5 my load becomes 13.75lbs/in. Both ends are fixed. I'm also choosing a beam were it's deflection is based on span/360 = 100'/360 = 0.2777' = 3.333". Is my setup correct for treating as a beam with the fixtures I have?
- Board index CAD SolidWorks SW Simulation
- Search
- It is currently Tue Dec 24, 2024 1:08 pm
- All times are UTC-05:00
Treat as beam simulation setup
Jump to
- Welcome New Members
- ↳ Welcome
- ↳ Forum Rules
- CAD
- ↳ CAD Agnostic
- ↳ SolidWorks
- ↳ How To Questions
- ↳ SW General
- ↳ SolidWorks FAQ
- ↳ API
- ↳ Macro Library
- ↳ SolidWorks PDM
- ↳ 2D Drawings
- ↳ Routing-Electrical-Piping
- ↳ Surfacing
- ↳ Rendering - Visualize - Photoview
- ↳ SW Simulation
- ↳ SW Motion Analysis
- ↳ Enhancement Requests
- ↳ Solid Edge
- ↳ NX
- ↳ Onshape
- ↳ Creo
- ↳ Inventor
- ↳ Fusion 360
- ↳ KeyCreator
- ↳ Catia and 3DX
- ↳ IronCAD (CAXA)
- ↳ Shapr3D
- ↳ CAD Admin (Install, PDM, etc)
- ↳ subD and Mesh
- ↳ Hardware
- ↳ Misc CAD
- ↳ Draftsight
- Other Technology
- ↳ Computer Aided Engineering
- ↳ Rendering and Motion
- ↳ 3D Scan
- ↳ General Engineering and Design
- ↳ AI and Related Tech
- Manufacturing
- ↳ 3D Print
- ↳ CAM
- ↳ PowerMILL
- ↳ Molding, Casting, Powder Metal
- ↳ Robotics
- Board Business
- ↳ General Biz and Announcements
- ↳ Suggestions
- ↳ What's Wrong?
- ↳ What's New
- ↳ Events
- ↳ Media and Advertising
- Off Topic
- ↳ Kitty Dump
- ↳ Job Listings
- ↳ For Sale and Want To Buy
