Reset Light Sources
Library for macros
Stefan Sterk
Answers: 5
x 73
x 88
Reset Light Sources
Unread post by Stefan Sterk »
Here is a simple macro which gives you the power to easily reset your light sources within a SOLIDWORKS Part or Assembly model by deleting the current light sources and adding back the 'default' (user specified) light sources.
Option Explicit
Sub main()
    Dim swModelDocExt As SldWorks.ModelDocExtension
    ' Get SolidWorks Application
    ' Get active model document
    Set swModel = swApp.ActiveDoc
    ' Check for active document and if document is a Assembly or Part
    If swModel Is Nothing Then End
    If swModel.GetType <> swDocASSEMBLY And swModel.GetType <> swDocPART Then End
    ' Delete current lights
    DeleleteLights swModel
    ' Add a directional light source
    SetAmbiantLightSource swModel, True, RGB(255, 255, 255), 0.3
    AddDirectionalLight swModel, "Directional1", True, RGB(255, 255, 255), 0.1, 0.3, 0.3, True, 90, 45
    AddDirectionalLight swModel, "Directional2", True, RGB(255, 255, 255), 0, 0.1, 0.3, True, -154.41, 37.77
    AddDirectionalLight swModel, "Directional3", True, RGB(255, 255, 255), 0, 0.2, 0.3, True, -101.07, 19.94
    ' Rebuild model to show light
    swModelDocExt.EditRebuildAll
Function DeleleteLights(swModel As SldWorks.ModelDoc2)
    Dim i As Integer
    For i = swModel.GetLightSourceCount - 1 To 0 Step -1
        swModel.DeleteLightSource i
    Next i
End Function
Function AddDirectionalLight( _
    swModel As SldWorks.ModelDoc2, _
    LightName As String, _
    OnInSolidWorks As Boolean, _
    Color As Long, _
    Ambient As Double, _
    Brightness As Double, _
    Specularity As Double, _
    LockToModel As Boolean, _
    Longitude As Double, _
    Latitude As Double _
    Dim X As Double, Y As Double, Z As Double
    GetCartesianCoordinates Longitude, Latitude, X, Y, Z
    swModel.AddLightSource LightName, 4, LightName
    swModel.SetLightSourcePropertyValuesVB LightName, 4, Brightness, Color, 1, X, Y, Z, 0, 0, 0, 0, 0, 0, 0, Ambient, Specularity, 0, Not OnInSolidWorks
    swModel.LockLightToModel swModel.GetLightSourceCount - 1, LockToModel
End Function
Function GetCartesianCoordinates(ByVal Longitude As Double, ByVal Latitude As Double, ByRef X As Double, ByRef Y As Double, ByRef Z As Double)
    Longitude = (Longitude * (3.14159265359 / 180))
    Latitude = (Latitude * (3.14159265359 / 180))
    X = Cos(Latitude) * Sin(Longitude)
    Z = Cos(Latitude) * Cos(Longitude)
    Y = Sin(Latitude)
End Function
Function SetAmbiantLightSource(swModel As SldWorks.ModelDoc2, OnInSolidWorks As Boolean, Color As Long, Ambient As Double)
    swModel.SetLightSourcePropertyValuesVB swModel.GetLightSourceName(0), 1, 0, Color, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, Ambient, 0, 0, Not OnInSolidWorks
End Function
x 2382
x 1990
Re: Reset Light Sources
Thank you. I was just going to start asking about / looking for such a macro. oa
loeb
x 43
x 14
Unread post by loeb »
I wrote a similar one that deletes all lights and sets ambient to 1. Now all our parts that are the same material look the same.
x 2382
x 1990
I find 1 to be a bit too bright, but I am doing the same thing.
x 230
Unread post by Dwight »
Stefan
Your Reset Light Sources works well, is just what I need. I tried to add some lines to turn the background to "none", but clearly I don't know what I'm doing. Could you suggess some lines to add, maybe also set the rest of the "scene" basics?
Thanks
What doesn't work:
Sub main()
SetAmbiantLightSource swModel, True, RGB(255, 255, 255), 0.5
AddDirectionalLight swModel, "Directional1", True, RGB(255, 255, 255), 0, 0.5, 0.3, False, -20, 30
AddDirectionalLight swModel, "Directional2", True, RGB(255, 255, 255), 0, 0.1, 0.3, False, -180, 45
' Set Background to none
Set Scene.BackgroundType = "none"
gupta9665
Answers: 28
x 466
x 504
Unread post by gupta9665 »
Replace
with
Dim swConfig As SldWorks.Configuration
Set swConfig = swModel.GetActiveConfiguration
Dim Scene As SldWorks.SWScene
Set Scene = swConfig.GetScene
Scene.BackgroundType = 0
x 230
Thanks very much, Deepak, that worked just right.
x 230
Dwight wrote: Wed Feb 19, 2025 2:02 pm Thanks very much, Deepak, that worked just right.
Actually, not quite. All works except that the . . .
. . . does work but doesn't stick. If I change configurations, the background will revert to its previous state. I searched a little, got a clue, and found that . . .
Scene.BackgroundType = swSceneBackgroundType_e.swBackgroundType_None
. . . works and does stick.
x 230
But . . . you have to do that for each configuration. That seems odd because when you open the scene properties window and edit it there, the setting applies to all the configurations. I didn't know you could even have different scenes for different configurations.
Stefan Sterk
Answers: 5
x 73
x 88
Dwight wrote: Wed Mar 05, 2025 1:25 pm But . . . you have to do that for each configuration. That seems odd because when you open the scene properties window and edit it there, the setting applies to all the configurations. I didn't know you could even have different scenes for different configurations.
Hi Dwight, use this code instead. It will set the Scene background type to none for each configuration.
    Dim vConfigName As Variant
    For Each vConfigName In swModel.GetConfigurationNames
        swModel.GetConfigurationByName(vConfigName).GetScene.BackgroundType = 0
    Next vConfigName
It's bit strange indeed, because display states can also have different scene settings, but via the API there are no scene option under the display states.
changing the scene via the configuration seems to override all linked display states.
x 230
Stefan
Thanks, that does it, works efficiently.
