Hi all,
In the attached file, the two features in question are "Circles_Outer" & "Circles_Inner". Anyway, these two features had been showing up fine. But after doing some assembly modeling involving this part file, these two features just kind of disappeared without warning...
It's especially odd because when I go to edit the features, the previews show up just as intended.
Anyone have any advice? All help is appreciated !
Thanks in advance,
Simple Features Disappearing w/o Warning?
- x 26
- x 3
- Base.SLDPRT
- (421.17 KiB) Downloaded 45 times
- x 2419
- x 2061
Re: Simple Features Disappearing w/o Warning?
That's an easy pz one.
You have the message checked to never show again for deleting things.
Because of that, most likely a face was selected when you deleted perhaps a part inside the assembly, and the features were deleted along with it.
The preview still shows it because the modification was made in the assembly rather then the part. The preview does not update if you modify a part from the assembly without opening it.
Hidden messages are really a P.I.T.A. especially when it comes to child/parent relationships.
