How to skip identical parts with GetComponents
Programming and macros
Wasermelone
Unread post by Wasermelone »
Hello everyone,
I have written a macro that goes trough all components in the assembly and subassemblies and makes drawings from all the parts. However I have a problem that if the part is used more than once in a assembly (on the top level and/or in the subassembly) it makes a drawing for each instance of the part so there is as many drawings of the same part as there is instances of that part. Is there are way to skip identical instances? Maybe I'm missing something about GetComponents method?
Thank you
Answers: 56
x 898
Re: How to skip identical parts with GetComponents
Unread post by JSculley »
Create a List or Array. After you process a component, add its path to the list. Before you process a component, check to see if its path is in the list, and skip it if it is.
Stefan Sterk
Answers: 5
x 73
x 88
Unread post by Stefan Sterk »
I start by making a list of unique components and then loop through it. as demonstrated by the code below
Option Explicit
Sub main()
    Dim swUniqueCompList() As SldWorks.Component2
    Dim swComp As SldWorks.Component2
    Dim vComp As Variant
    Set swModel = swApp.ActiveDoc
    If swModel Is Nothing Then End
    If swModel.GetType <> swDocASSEMBLY Then End
    swUniqueCompList = GetUniqueCompList(swModel)
    For Each vComp In swUniqueCompList
        Set swComp = vComp
        Debug.Print swComp.GetPathName
    Next vComp
Function GetUniqueCompList(swModel As SldWorks.ModelDoc2) As SldWorks.Component2()
    Dim swConf As SldWorks.Configuration
    Dim swRootComp As SldWorks.Component2
    Set swConf = swModel.GetActiveConfiguration
    Set swRootComp = swConf.GetRootComponent3(True)
    ReDim swUniqueCompList(0)
    Set swUniqueCompList(0) = swRootComp
    TraverseComponent swRootComp, swUniqueCompList
    GetUniqueCompList = swUniqueCompList
End Function
Sub TraverseComponent(swComp As SldWorks.Component2, swUniqueCompList() As SldWorks.Component2)
    Dim vChildComp As Variant
    Dim swChildComp As SldWorks.Component2
    For Each vChildComp In swComp.GetChildren
        Set swChildComp = vChildComp
        If Not IsCompInList(swUniqueCompList, swChildComp) Then
            ReDim Preserve swUniqueCompList(UBound(swUniqueCompList) + 1)
            Set swUniqueCompList(UBound(swUniqueCompList)) = swChildComp
        End If
        TraverseComponent swChildComp, swUniqueCompList
    Next vChildComp
Function IsCompInList(swCompArr() As SldWorks.Component2, swComp As SldWorks.Component2) As Boolean
    For Each vComp In swCompArr
        If StrComp(vComp.GetPathName, swComp.GetPathName, vbTextCompare) = 0 Then
            'If StrComp(vComp.ReferencedConfiguration, swComp.ReferencedConfiguration, vbTextCompare) = 0 Then
                IsCompInList = True
                Exit Function
            'End If
        End If
    Next vComp
End Function
Wasermelone
Stefan Sterk wrote: Sat May 21, 2022 4:25 pm I start by making a list of unique components and then loop through it. as demonstrated by the code below
Option Explicit
Sub main()
        Set swComp = vComp
    Next vComp
End Function
        End If
    Next vChildComp
                IsCompInList = True
                Exit Function
            'End If
        End If
    Next vComp
End Function
Thank you, this worked flawlessly!
